Found a Stage1 Super M LP
CenTex Farmall
First Stage 1 I've found with factory LP. Has the Tulsa tank and correct plumbing. CJ code. Has a gear reduction starter, pull type.
The front wheel is IH but we usually see these with the 16" wheels.
Someone added a nice oil filter (Purolator?) and an M&W throttle handle. Still sporting a two tone paint scheme from one of the repaint programs.
Was it by any chance from Louisiana? I had heard about one that someone had found and didn't know what to do with it...anyway, lucky you & congratulations! Hugh
This one was in the vicinity of Austin. Clean-ish oil and anti-freeze in the radiator. Drained the water out of the rear. That's as far as I've gotten.
Pistons are stuck but crank is loose.
