Fox Super E hydraulic issue solved
Bought the Super E two years ago in Lancaster New York, and hauled it up to Ontario. The machine had sat for 20 years in a shed. The hour meter has 1400 original hours and the machine looks like new. When we were loading it, the hydraulics were slow and unresponsive. I was told by a friend that the hydraulic filter can become saturated with oil if it has sat a long time without running -I have never seen this situation at the Deere dealer where I work.I started the machine a month ago and checked the hydraulic system. There was a gauge connected to the discharge side of the filter housing that connects to the pump. I checked out the gauge and relized that it was a vacuum guage - reading 25 inches of vacuum! - I checked the manual and it said change filter when guage reads in the red zone - this one is in inches. I drained the reservoir by removing the filter cannister. The oil had a lot of gel like deposits floating in the oil. Basically, the filter was plugged from the gel in the oil. Flushed out oil reservoir with diesel fuel. Installed new filter and new HY Gard oil started the machine and touched the foot pedal to raise the 3 row wide head. The head jumped to the top limit in seconds. The steering is now one finger easy. The vacuum gauge now reads 10 inches in vacuum while running. This weekend change engine oil and filter - change dry air filters that are dated 1974 and 1975 - original air filters! Going to put the newer style lowered profile 3 row narrow corn head that is on the Super D and install the older high profile 3 row narrow on the Super D that is on a Super D gasoline machine that I bought last year.
Ken
