BANDITFARMER
After the trial run after getting one of the hubs shafts rebuilt today I was going over it and found one of the seed tubes is bent and the inside wore off. I think I can fix this with a torch and a piece of scrap stain less steel to weld on it.
I noticed in the book how to level it and set the depth. Now with the discs set the way they are it seam to me that the back row will plant shallower then the front set. Can the back set be moved forward one hole to get better depth like the front?
With the press wheels holding it as the pivet point it just seams it would be hard to keep both front and back at the same depth. It just looks like it would work better if the back set was moved forward just one hole, Or maybe not. Maybe the seed tubes need to be set different for the front and back disc to get the same depth. Anyway you can see the bent seed tube on the front disc that I have to fix. Bandit
