Freeze plug removal 3000
Dale Berman
I have tried for a week to remove the freeze plug (located behind the starter) on my 3000 Diesel. I bought a grade 8 bolt and welded a nut to the end (the bolt snapped in half), I bought another one and tried it again with an impact wrench. I heated it with a propane torch with no luck as well, maybe I need to get an acetelene (sorry for the spelling) torch. Has anyone ever removed one of these plugs? I really want the block heater (which I already have) instead of other options. Any advice would be greatly appriciated.
Many thanks!
Thanks Shaun. I'll have to keep trying. I might take it to the local highschool who has a torch set. Lokks like I'm gonna have to heat the crap out of it. Is there a way to freeze it? Common sense and lifes lessons tells me that cold makes things shrink.... I just would know how to concentrate pure cold to just the plug.
(quoted from post at 19:17:16 05/10/12) Thanks Shaun. I'll have to keep trying. I might take it to the local highschool who has a torch set. Lokks like I'm gonna have to heat the crap out of it. Is there a way to freeze it? Common sense and lifes lessons tells me that cold makes things shrink.... I just would know how to concentrate pure cold to just the plug.
Nitrogen....
Nitrogen... I was just thinking...would that make the surrounding parts brittle? How do I go about getting some?
Thank you,
Dale
Dale, if (and I don't know), your freeze plug is a soft material (brass), could you reach it w/a torch and melt it out. I am not familiar with the threaded type. maybe drill and break pieces of it out??
Steve and or Carol,
My plug is not made of brass....I wish it were. There are 2 other plugs just like the one I'm trying to remove in different locations. One on the rear of the cylinder head and another right below that one, but when the tractor is put back together both of those plugs are hidden and there is not enough room for the heating element to fit with everything put back on. I had to pull my fuel tank, clean it out, and seal it. I had a bad bad rust problem. I called my tractor shop yesterday and their gonna put me in touch with a guy who works on these. I'd rather try and have them get the plug out. I'm just worried that I'll end up screwing something up bad if I put too much heat on that plug.
Thanks for the ideas if it were brass though.
Dale
With talking to alot of different people, even thought I"ve already purchased the block heater, I"ve decided to just put a lower radiator hose heater in. Im afraid that if I try too many more times on that freeze or casting plug, that I will cause damage that would be un-repairable.
Thank you all for your input on this matter.
Dale
