Frey loader hydraulics
56 Massey
Any suggestions on who to contact for a replacement part. The plunger(?) in the valve body broke at the bolt hole. Or other alternatives. I'm mechanically but not with hydraulics. Thanks!
Very few valves can have a valve spool replaced as they are often fit to the bore. My thought is you need to start looking for a complete, new valve to replace it.
It appears Frey stopped building loaders in 2019 and parts support has likely gone by the wayside. Looking at a parts book online for the Frey WL165 loader it appears you need to first identify the valve your loader has. The book shows a Valvoil SD5 and a Bondioli were used.
Have you called the phone number on the FREY website?
FREY loaders
You can always take it to a machine shop and see if they can weld or otherwise repair the spool. That could cost as much as a valve and still not work just right.
Edited to add valve parts drawings
Upvote 0
Thank you. It appears that the part that is broken is the fulcrum. I'm thinking of taking it to a machine shop and see if one can be built or weld this one up.
Upvote 0
