Friction drive
Chuckny
I realy don"t know where to post this question as it is on a snowblower. Hope someone has an answer. I have a 9HP Craftsman 29 inch wide snowblower. It has a friction drive and has been slipping since new 6 years ago. Sometimes it won"t even move when i close the lever. I have replaced the drive pully that engages the drive plate twice. The last time was last year. I cleaned the drive plate with alcahol to make sure there was nothing on it that would cause it to slip. Any help whould be appreciated.
Some friction disk drive systems have 2 tension springs on friction drive tire/wheel drive assembly,one of the springs may be disconnected/broken,also depending on mfg of blower some models have a tension adj for drive tire/friction disk pressure,check parts list in owners manual to locate above items,also check for any adj instructions in manual,if no parts list,goto link below,enter mod# off id tag,print all drawings in parts list.Try washing friction drive tire,you may have oil/dirt on same,also don't leave blower stored/parked in gear,will put a flat spot on drive tire.
sears
