friction torque cluch
I am looking for a friction torque cluch for a 1000 rpm and cost. it needs to have a bolt on the outside rather than a center hole or shear pin. it needs to be a female on the shaft side and a male on the side toward the tractor
do you know where one is that will reduce down from a 1000rpm to a 540 rpm it needs to be a bolt on the side of the 1000rpm side for the shaft this will be a femal and the other side toward the tractor will be a 540 male and cost of both
So we had a little fun at your expense. Do you want an answer? Do you want to be a part of the group? Some of these guys have been 'here' since 1997 or 1998; there's probably as much general/broad-based knowledge on these forums as exists anywhere in the world. A flail mower.......around 'here'...... turns like an old push-type reel mower. The terminology may be different in other places. Is that what you've got or do you have a rotary (bush/brush hog) type mower? Give us a model number.........a picture would be as good or better.
What?????????? Are you talking about. Are you saying you need a 21 spline female gearbox end and a 7 spline male end,tractor side,SLIP CLUTCH ASSY> or a gear reduction unit.??? Make, model machine sure would clarify things a lot.
