front end alingment
in sticks
bent the tie rod on tractor, now that it,s sorta straight.what is the correct alingment on front wheels? toe in,toe out,or neutral
Don't know what kind of tractor you have but we set most of the ones we deal with 1/4" toed in. If you toe them out they shimmy when on the road at high speed.
1/8 to a 1/4 toe in....they will toe out as you move forward, so add more toe in as your front end components get sloppier.
if it's 4wd and you use it in 4wd mostly, toe it out about a 1/4"... drive wheels usually induce toe in as they drive forward
