Front end loader for 1948 Ford 8n
mauditfou
Hi
I just bought a 1948 Ford 8n with original snow blower for a moderate price. I am in the process of moving and starting a small hobby farm out here in the country. I am new to tractors and am looking for some advise on the type of loader that would accommodate my needs.
I won't be using the loader for any heavy lifting and I am aware that my tractor is not the most efficient for a loader.
I've posted some wanted adds and I have gotten a couple replies with some loaders available but i am unsure if they would fit on my tractor. Here are some examples of loaders some people say would fit but are also uncertain.
-1957 ferguson 35 loader
-1953 ford Jubalee trip bucket
Can someone advise me on this subject.
Eric
Have you considered a rear scoop. This one is not
reversible but some are.
Both of the tractors/loaders are a bit longer than an N so keep that in mind when you buy.
Some loaders will have slots or extra holes where they hook up to the rear axle and will fit both the longer/shorter machines.
Another thing I would have you consider is how a loader will make a behemoth out of your otherwise nimble little tractor.
If you are certain that the majority of the work you will do with it requires a loader then by all means put one on.
But a loader will make it unhandy for many other tasks like mowing, disking and plowing.
As HCooke says below, a rear scoop is very handy for hauling dirt, rocks, mulch, tools, feed, fertilizer, etc, especially if you get a reversible one.
And for lifting engines, or other heavy stuff into your pickup or onto a trailer a 3 point boom pole works very well.
With both tools you can often get by without a loader untill such time as you find a tractor more suited for loader work.
Thanks to Bill GA for the use of this photo.
Not sure of the loaders you listed. I have been well pleased with
the Wagner loader on my '48. It's the Jungle Jim. A step threw
would be nice. But if you are in good shape, climbing on from
the back is not that bad. I wouldn't want a trip bucket. I've used
mine for plowing and bush hogging with no problem. It even
comes in handy in hogging threw some of the thickets I go threw
to push or raise limbs out of the way.
Also handy for lifting shingles up to the roof top or raising up
and holding a deer for skinning. Not going to do that with a rear
scoop or boom pole.
While you can do every thing with a loader tractor, I do
recommend a second tractor to do work where the loader is not
required. You can pick them up prettier cheap. So why not have
more than one?
mauditfou.......umm......you do know the difference between 8N's and Jubalee's don't you? 8N's have a flathead engine and Jubilees have OHV engine and "cyclops" hood. The Jubie has a 4"-LOOoonger wheelbase and you need to connect the loader to the AXLES fer the strength to PUSH with. Some loaders tap off'n the weak sister 3-point hydraulic pump. Good FEL's hydraulics are connected to the front crankshaft pulley with a spline'd coupler. The hydraulic fluid is "stored" in parts of the FEL frame tubes. Me? when I need FEL work, I go rent a yammabottadeer ...or... hire my professional back-hoe neighbor down the street. He sooooo FAST and sooooo SMOOTH. ......the amazed Dell
