Front end swap
I have a 720 tricycle front and a friend with a 630 wide front. I would like to swap to the wide front and was trying to find out if they will swap without major problems, Amy info is appreciated.
Watch out for something. With the narrow front end you have 4 bolts doing the turning and twisting to steer. With the wide front end only two connect to the tie rods to do the same thing. Once upon a time one of the two working bolts worked loose and sheared off disking stubble in an airless riverbend. Drilling that thing out with a breast drill in a half curled position just wasn't fun. Use a high grade bolt and torque it to the specs for the bolt. Use some loctite and check them for tightness every twenty four hours of runtime. That may seem a waste of time, but it's cheap insurance. Trust me on that.
Going from memory, I ''think'' that those bolt lengths are different in the parts book too.
