Front end weights for 130
I"ve about 6 performing stage curtain weights. Steel, weigh about 60 lbs. apiece, rectangular and slotted. Looking for suggestions on how I might mount them on my 130.
Thanks in advance for your input
Ron: You want mounting for these, yet use you cultivator at same time, right or wrong. i'll send you a photo of a device I use. It hooks to those tabs on back side of cultivator mount, beaced to clutch housing and extends forward under axle. Weights mount out front of tyrods.
Hugh not to get off topic, but is that a sidedresser on the front of your 140? I have been looking for a good setup for one. Thanks
Hugh,
The only time I need front weights is when I'm using my two-way plow, or my disc. I do have cultivators for the tractor, but don't need front weight when using them.
RDJ: That is actually a dry chemical applicator made by Gandy. When I grew rutabagas, I had a two row planter center mounted on cultivator lift. The Gandy was used to lay down a band of chemical in front of each planting unit.
