Front End Weights
jsp5755
Does anyone know which tractor these front end weights fit?
Is it the smaller size that fits like a 3600, 4600....or is it the size that fits the 6600, 7600?
Most weights fit a pretty broad range of tractors. Those look like the ones that I had that came on a 5000.
Like Bern said.
Those APPEAR to be the smaller, 60-ish
pound weights. My 4600 came with those,
while my 7000 and 7600 came with thr
larger ones. However, they will
interchange on the 3 and 4 cylinder
model's brackets. The 6 cylinder models
use a taller bracket and these won't hang
properly on the tall bracket.
Those.... look just like the batch of 40 lb???? weights that I sold a couple of months back that come off a compact ford tractor.
I'd second the suggestion that you weight them... but they look identical to the set I have which are 75#. We have them on a 4000,
but I believe they could be used on just about any model you make a bracket for...
Rod
