Front hydraulic pump rebuild or replace??
booyah11
Have a Dearborn loader that needs a refresh. Couldnt find any info by searching for the casting numbers on the pump.
https://www.flickr.com/photos/cosjagos/42374104915/
Numbers I came up with
05-485
05100205002
1AA9H
Id prefer rebuilding if possible but as I cant find this pump anywhere that is unlikely. Help on a replacement?? Thanks.
(quoted from post at 19:28:35 06/06/20) Have a Dearborn loader that needs a refresh. Couldnt find any info by searching for the casting numbers on the pump.
05-485
05100205002
1AA9H
I believe that is an old Cessna pump. Just replace with a new inexpensive gear pump - run you about $150 delivered to your door.
TOH
Right on, thank you sir. You calling it a gear pump is exactly what I needed. When searching for hydraulic pump I got lots of results that were not what I was looking for. Thanks!!
