Front Loader Ford 4000
Wyman 861
I have a front Loader on a 4000 ford I am using quick connects for the loader. I replace the loader control valve because after you curl the bucket it would not hold unless you stay on the valve. NEW VALVE is on and the loader is doing the same thing. Please help. Thanks Wyman
Internal leak in one or both of the bucket cylinders. Leaking past the piston seal from one side of the cylinder to the other so no visible external leak.
Disconnect hoses on one side and cap off the hoses end off, it still does it then that's the bad cylinder is till hooked up.
