front loader pump
ok, sorry for all the questions, but I just need the help.53 jubilee, have to replace front axle support, install new fan belt. It has a superior loader on front, can I just take the pump off, remove bolts from crankshaft and pull it out of my way to get the job done, ----or do I have to remove the loader completely? also, if I undo boltd at crank will I be able to get fanbelt thru? Thanks for any help or advice. Can't tell you guys how helpful this forum is and has been, really appreciate it, Tom
hippie, you're talking about the bolts that go into the crank pulley, right?Or pull the pump out altogether, I don't have a clear picture in mind, sorry
Loosen the pump from its mount. After removing bolts to crank. Did not remove the pump
If the rain stops Ill try to get a pic
Just changed the fan belt on my 850 with a front mount pump. I just removed the bolts from the pump mount and slid it forward. It was enough to belt the belt thru. Tight squeeze but it worked.
Clay
