FRONT LOADER PUMP
Bill Gassner
I am having a problem keeping adaptor hub 191196 and crankshaft pulley 192152 ( with the 4 rubber bushings) from kicking out (comingb apart) and now I need to replace the pump seal where can I get it. thanks Bill
Is your two shafts aligned up so it isn't putting undue stress on that rubber coupler. They could be out of alignment.
As for the pump seal not enough info to give you any meaningful answer.
People used a score of different pumps on old Ford loaders over the years. A lot of them a guy can find parts like seals etc at your local bearing house or even a Oreilly's or Napa. You would have to beable to scrutinize the seal close enough to get a number to cross refrence, even if that means removing the seal.
