greywolf224
Rebuilding a front mount. When I took it apart, there was grease pretty much splattered everywhere.
I am thinking to use carb cleaner on the break plate assy and the cam weight assy to get all grease off.
When putting back together do I need to put any special lube on the upper and lower shaft bushings or on any part of the cam weight assy?
I'm thinking that the only lube needed would be for the shaft lobes that the rubbing arm rides on?
