SouthernThunder
MF 30 backhoe. My backhoe and FEL are weak and jerky. New filter and fluid. I suspect the front mount pump has gone out. Filter was full of junk from when the packing went out in the boom cylinder and I think it may have starved the pump to death.
I wanted to take this pump off to inspect it. I removed both the lines and the two bolts that bolt it to the frame but it won't pull off. It look like it has a splined shaft. Is it safe to pry it off the frame? Surely I don't have to pull the FEL off and unbolt the pully front the crank do I?
