Front mounted hydraulic pump
I was considering putting a loader on either an 8n ford or 135 massey. Both tractors i think you can put a front mounted hydraulic pump. What pump does most people use? Where do you get the pumps?
Any advice or information is appreciated thanks
Does the Massey have power steering? If so that would be the one to use.
Neither is well suited for a loader, weak front suspension.
My emails open. I believe I have the pump setup that came off my dads 8n. Don't have any use for it. I should also have the tank and valve. It was just a trip bucket loader. I'm located in Mendon Michigan. Your welcome to come look at it even if you don't want it. Will have to work out a price if you want it.
I agree with Steve.the 135 is definetly the best of the two tractors.Personally I would hate to have a loader on an 8n.
Rock
Ok thanks
It just depends on which tractor i keep and which one i sell.
My loader is a trip style bucket. It came off ford jubilee. Ive been told it could be made fit the massey 135 or the 8n
Before getting overly complicated . How about mounting the loader on the 135 and use the 135s factory hydraulics as a start ?
(quoted from post at 22:55:42 12/03/20) Ok thanks
Not hard to change a trip loader to a hydraulic set up. I wouldn't sell off a 135 and keep an 8N no matter what. The 135 is many, many times the tractor the 8N is in every possible respect. IMO it would be the height of foolishness to keep the 8N.
Doesn't have factory hydraulics other
than the 3 point hitch. There ain't no
remote or anything. But yes that would
be the easiest
