(quoted from post at 12:06:41 10/15/20) The Sauder is unique as it is a "quick attach" once the mounting brackets are on the tractor. Would have to be careful plowing snow with one as there is no trip mechanism or springs that snow plows have to prevent coming to an instant stop or bending up the plow frame if hitting a frozen edge. The Dearborn snow plow has trip springs.
have that same unit. I had assumed that the previous owner had added the brace to accommodate the 6 cylinder engine length. Now I see the original used both mounting braces. The mounting bracket was modified to catch the rear brace. What model is yours and where would the tag originally have been?(quoted from post at 15:34:47 10/16/20) I have a Blackhawk in eastern Iowa. Requires a hydraulic hook-up.
(quoted from post at 04:45:10 10/16/20) I have a Dearborn front snow plow with skids and tire chains for
sale in central Michigan. Front mounting brackets are original,
rear brackets are not original. Needs a cable replaced.
It came with a 9N I bought. I've never put it on.
If you're interested my email is open on modern view.
Model is AD 456 I think - it's not completely clear. It's right behind the bracket that bolts to the front axle (I think! It's too dark out now to see!)
(quoted from post at 16:43:47 10/17/20)d Gooding posted the ARPS/Blackhawk manual on the N Board under manuals. The blade is designed to work off of the tractor hydraulics or with the Sherman backhoe.What model is yours and where would the tag originally have been?
