Front remotes on a Case 930?
pard
I remember reading about someone with a bad PS on their 930 and they swapped it out with a PS from another Case model that had a set of hydraulic remotes. I can't figure out where I read about this or any idea of what PS to swap in.
My PS is dead is a doornail. It turns just as easy with the engine off as on, which is to say it doesn't turn much at all. Since I am going to be digging in the front I thought it might be interesting to try and get this PS with a remote up front swapped in, might come in handy, always thought a forklift attachment stuck on the front of a tractor with a hay spike would be a lot better way of monkeying bales around then with the loader.
Some change the hydraulic pump for one
from a 70 series and use the second outlet
like is done in the 70 series. Does your
pump have oil in it? As ir front remotes,
just run hoses from the rear up front. You
can run the pressure hose between the pump
an valve through an addition valve if you
want more outlets too.
Check your upright spindle bearings, tie rod ends and the universal joints on the steering shaft, don't forget about the one under the radiator
