front rim 2240
Front rim on my 4wd 2240 takes a 9.5x24 tire. The rim has 6 welded studs that bolt onto an 8 hole wheel. Turns out that Deere doesn't carry them any more. the one I have is so far gone that it can't be welded,out of round and edges rolled over. Any idea where I might find one? web search of junk yards unprofitable. Are there specialty wheel sites that might help? or some other source? thanks
I don't know if this will help or not, but Miller Tire offers a 8X24 and a 9X24 flat base rim for $80 and $90 respectively. If I understand you correctly about your wheel, the center bolts on to the rim???? Could you cut the mounting lugs off the old rim and weld them to a new rim and use the old centers (assuming the centers aren't also too bent up to use)? Just throwing out a possibility. Mike
Miller Tire
Yes, the center bolts onto the tractor and to clamps on the inside of the wheel see picture. the holes 11" center to center and the clamps are 19.5 center to center. as you can see, things are pretty far gone. thanks for the suggestion
https://photos.yesterdaystractors.com/gallery/uptest/a4465_sml.jpg
Go to
http://www.worthingtonagparts.com/low/Salvage/ImageView.aspx?from=Salvage.Aspx&Type=T&Make=JD&Model=2750&sString=Tractor%2c++John+Deere%2c++2750&txtType=1&PartsNo=&PurchNo=07-26L-0026
all these tractors use this wheel if front wheel drive
1764 - 2240 (350000- ) Tractor - 09Jun08
4172 - 940, 1040, 1140 Tractors (European Edition) - 01Aug06 ( FR DE IT ES SV )
4173 - 1640, 1840, 2040 Tractors ( -429999) European Edition - 01Aug06 ( FR DE IT ES SV )
4182 - 2150 and 2255 Tractors (North American Edition) - 28Feb07
4184 - 1640, 2040, 2040S Tractors (430000- ) - 01Feb08 ( FR DE IT ES SV )
4187 - 2350 and 2550 Tractors (North American Edition) - 01Feb08
4188 - 2750 Tractor (North American Edition) - 27Feb07
4212 - 1550, 1750, 1850, 1850N Tractors (European Edition) - 06Feb08 ( FR DE IT ES SV )
4215 - 2755 (GPT) and 2855N Tractors (North American Edition) - 28Jan08
4216 - 2355 and 2555 General Purpose Tractors (North American Edition) - 28Jan08
4217 - 2155 and 2355N Tractors (North American Edition) - 23Jan08
4224 - 1950, 1950N Tractors (European Editon) - 06Feb08 ( FR DE IT ES SV )
MAY GOD BLESS THE USA
