front tire size on a 600
fil front tire is flat on his 600 and was wondering if we could use the one off the naa. his tractor is about 3 hrs from here so we cant just go and look
Well if both use the 6 hole small bolt pattern yes they will switch. Shoot almost any farm tractor/equipment 6 bolt wheel will fit on them. I gotten by a good number of times tkeing a rim off a hay rake or baler and put on the front of my tractor just to get a job done. But a 6 bolt rim from a chev truck will not fit
Hobby farm
Yes.. should fit. I keep 2 spare tires which are rims / tires from my NAA.. I have one of those spares on my 850 right now.. and they are the same as on my 660 as well..
As long as you havn't change dthe hub out to something non ford from that time frame.. it should work fine.
Tires may be mismatched.. but pivoting front axle will semi-take care of it.. turns me be sharper ont he smaller tire.. so be mindfull if there is a big tire size difference.. though there shouldn't be much height difference.. although width could certaintly be different.. etc..
Soundguy
