Front wheel bearings on a TO20
Are the front wheel bearings on the TO20 interchangeable with the 8N or 9N? I need to order some as the bearings are grinding on one wheel. I figured since I had it up in the air, I might as well do both of them. Any help is appreciated.
Roger
Why don't you just order them for the TO 20? This site has them and I might say rather reasonable also. At the top left of this page click on "Tractor Parts" then follow through the bearings are located towards bottom of the "Wheel" page.
If the bearings are as bad as you say you may find that the Stub Axles are worn now and could require replacing. Check and adjust the bearings regularly and make sure that the hubs are full of CLEAN grease it can get expensive if you neglect maintenance....John (UK)
