Front Wheel Ring Spacers
UseFixUse
I have a 641 with FEL and light industrial axle. I would like to gain a little space between the steering arm bolt housing and the tires without reversing the rims. Once in a while, the metal just barely kisses the tire. Tires are 6.00-16 light truck with 45psi. I think a quarter inch thick ring wheel spacer would be adequate if I could find a couple. There are plenty of wheel spacers of online but none look applicable. Any thoughts are appreciated. Thanks.
I ran some truck tires on a 3400 front
axle which is the same style as yours.
That bolt wore a groove in each tire.
It wore the rubber off but did not wear
into the cords.
I didn't worry about it and ran it like
that for a couple of years.
