Front wheel
Kurtb
Trying this again, can anyone tell me what parts Ill need to fix this? Does anyone ship overnight?
Wow! Looks like the spindle shaft is broken off. How is that possible? The 9N & 2N use p/n 2N-3105(RH) and 2N-3105(LH). they are compatible with the 9N wheel hub as you show your BUDD WHEEL hub. Spindle don't cross with 8N ones BUT, you can replace the parts with 8N spindles then get a set of 8N 6 Bolt Pattern front wheel hubs. Tires are compatible, OEM are 4 x 19. New spindles at nnalert and Carpenter.
Tim Daley(MI)
I replaced mine with new ones from this site.. Everything went fine but there are bushings that probably need to be replaced as well.. I had a little difficult time getting them out with the bushing cutting tool I bought. Bushings and oil seals (dust covers) are also available here...
Kurt, I don't have a good way to ship, but I can check and see what
UPS would charge for it. My email is open on modern view if you
want to send me an email so we can discuss in person.
