MARK ROBKE
Ok-new search-I'm passing on the Titan tedder and found a Frontier model 1316 tedder. I believe John Deere still supports them(?) Has anyone used or owned one? What can you tell me-good or bad? Thanks, Mark.
Last time I checked, Frontier is supported by JD dealers....my opinion......a low cost option for implements that JD may or may not manufacture. On a Tedder, there isn't much to go wrong. You have an oil filled main gear box and gear boxes where the blade axles are mounted....some of those are oil filled or greased....I prefer the greased as you don't have to worry about seals leaking. The arms and Tynes are pretty much bullet proof. Some are combination side rakes and tenders. The side rakes tend but also have a side shield that the Tedder can toss the hay over and into the shield making it a Tedder and rake in one pass.......butttt. I tedd to achieve quick drying before I rake. I assume the dual purpose units allow you to do that, like on the tedding pass the shield is raised so that the grass can scatter to both sides of the tractor. After the grass dries, the farmer comes back with the shield down and the Tedder scatters the loose hay into the shield making a suitable windrow for baling.....if that's the case it saves having to buy a rake and a Tedder......my latest edition of Apple software on my computer is responsible for the indiscriminate use of words and capitalization on here....it also thinks it knows what words I am going to type and its a PIA to keep correcting it until it accepts that fact that its wrong and I am right......I hate it!!!!!!!Ok-new search-I'm passing on the Titan tedder and found a Frontier model 1316 tedder. I believe John Deere still supports them(?) Has anyone used or owned one? What can you tell me-good or bad? Thanks, Mark.
As deere4040 posted The NH 163 and Frontier 1316 are both KUHN built units, so you have access to 3 sources for parts. A couple things make sure you install the tines in the correct direction for the rotor rotation. And the newer KUHN tedders have the inner leg of the tines about an 1 shorter than the outer leg. The older tines, like yours will use, have equal length legs. We have started cutting the inner leg of 3/4 to 1 inch shorter and have been seeing less breakage as that lets the two run about the same distance off the ground when the tedder is tilted. You will want to find an Operator's Manual.Well, I bought it. As deere 4040 stated, it looks just like the New Holland. It is in pretty good condition, needs a few teeth, and the seller and I bargained a little and we both were happy. Thanks for all the info guys, Mark.
The dead give way is the ability to turn in the wheels/rotors when in transport position.Well, I bought it. As deere 4040 stated, it looks just like the New Holland. It is in pretty good condition, needs a few teeth, and the seller and I bargained a little and we both were happy. Thanks for all the info guys, Mark.
I ran my Pequea for 8 years until I figured out the teeth were backwards. Spent 8 years on forums researching, getting opinions, and not once was the idea mentioned that the teeth were backwards. Once I had that fixed it was like having a new Tedder. Could have had a new Tedder with special pricing and financing out of the deal direct from the owner of Pequea himself. It was an interesting ordeal.A couple things make sure you install the tines in the correct direction for the rotor rotation.
Pulling this out of my vague memory when I uncrated my first one, a 2 basket, the Tynes had their respective sides. On my JD rakes, 600 series, they had a particular position too. If backwards I can understand how they don't work very well.I ran my Pequea for 8 years until I figured out the teeth were backwards. Spent 8 years on forums researching, getting opinions, and not once was the idea mentioned that the teeth were backwards. Once I had that fixed it was like having a new Tedder. Could have had a new Tedder with special pricing and financing out of the deal direct from the owner of Pequea himself. It was an interesting ordeal.
Still have yet to replace one but yes poor performance.Tedder tines on backwards flex the spring coils the wrong way and lead to breakage as well as reduced performance.
Mark That I know of there were two drive systems One is a series of fingers or digits that is the good newer one. The other is a collar with pin and rollers older type. Do check that out and make sure its all tight to the shaft. This is where the outer two rotors connect to the inner. It should do you well and is top of the line brandsWell, I bought it. As deere 4040 stated, it looks just like the New Holland. It is in pretty good condition, needs a few teeth, and the seller and I bargained a little and we both were happy. Thanks for all the info guys, Mark.
I have seen that before-assembled wrong! Mark.I ran my Pequea for 8 years until I figured out the teeth were backwards. Spent 8 years on forums researching, getting opinions, and not once was the idea mentioned that the teeth were backwards. Once I had that fixed it was like having a new Tedder. Could have had a new Tedder with special pricing and financing out of the deal direct from the owner of Pequea himself. It was an interesting ordeal.
It has the fingers. Something I failed to notice - the gear box does not have a check plug for oil level, just has a flat plate on the rear. It does run quiet. Mark.Mark That I know of there were two drive systems One is a series of fingers or digits that is the good newer one. The other is a collar with pin and rollers older type. Do check that out and make sure its all tight to the shaft. This is where the outer two rotors connect to the inner. It should do you well and is top of the line brands
I believe you will find the gearbox has grease in it not oil. The Kuhn Operator's manual says something like 0.800 kg of #2 grease, I expect a Frontier Manual will be similar. (I tried to find an Operator's Manual at the JD Bookstore with no luck. The TD1316 parts catalog is available at jdparts.com.It has the fingers. Something I failed to notice - the gear box does not have a check plug for oil level, just has a flat plate on the rear. It does run quiet. Mark.
That's what I was suspecting. Thanks, Mark.I believe you will find the gearbox has grease in it not oil. The Kuhn Operator's manual says something like 0.800 kg of #2 grease, I expect a Frontier Manual will be similar. (I tried to find an Operator's Manual at the JD Bookstore with no luck. The TD1316 parts catalog is available at jdparts.com.
Mark Jim is correct mine had grease so here is a tip for you. On mine a Kuhn I drilled the housing and put a grease fitting in it so I can put fresh grease in it when I grease it. If its similar to mine and You use it much be judicious on greasing it overall. Mine has the older drive unit so i grease that too.That's what I was suspecting. Thanks, Mark.
