frozen trans
dan55
I have a 580ck 4 Cyl with a power shuttle trans.This winter it would not move found it had ice in trans. thawed and drained replaced fluid , but still doesn't move and no trans pressure. could use any advice.
Thanks Dan
Hi Dan,
The pump shaft could be broken off where the drive gear slides on.You will need to remove the top cover under fuel tank. You can do this without removing the fuel tank.
Marlin
