FSM fuel system
Bob-O
I took the fuel sediment bowl and fuel filter off my FSM. Am getting a new filter , brass screen and gasket for the sediment bowl tomorrow. After I reassemble these things, how do I go about bleeding the lines? Do I just disconnect the lines where they enter the head and crank until fuel spurts out and then tighten em up? Thanks in advance, Bob-O
PS What is that little thumb lever on the front of the fuel pump?
The lever on the side of the fuel pump is the primer. You can pump fuel with it when the engine isn't running.
To bleed the system, open the bleeder on the injector pump. Its the tall hex shaped plug below where the number 2 and 3 injector lines come out. Unscrew it a couple of turns and pump the primer lever until fuel comes out with no air bubbles in it.
Some people like to fill the filter canister up with fuel before they put it together, because its faster to prime the system. I don't do that because you're putting unfiltered fuel in the injector pump.
Close the bleeder and start the engine. If it won't start, bleed the injector pump by loosening the nuts on the injector lines on top of the pump and cranking the engine. Make sure the transmission is in neutral so you don't run over yourself. Better yet crank it from the seat. Tighten the nuts and then start it. If you have to take the injector lines loose at the top end, you will have to take the valve cover off and put a wrench on the adaptors that go in between the injector lines and the injectors. If you don't they will turn when you turn the line nuts and you could twist an injector line off.
Bleeding is pretty easy. You should have her running in no time.
Simple system that usually works for me. LOOSEN the out pipe on the fuel filter housing. (thats the right hand as you look at it) Then change the parts that you wish to change. I fill filter with fuel. Then pump the primer till fuel flows from the filter housing pipe joint. Tighten the joint and start the engine. If that doesnt work then you will need to do the whole bleed. Incidently if the primer appears not to work turn the engine half a rev or so on the starter. MTF
