fuel filter assembly replacement needed MF 35X
Tomtom1988
This message is a reply to an archived post by Cormiers Cove on July 12, 2017 at 14:49:01.
The original subject was "fuel filter assembly replacement needed MF 35X".
I want to buy one the same that?s in the picture
I have been trying to locate more of the filter head like I put on my 135, but I'm not having any luck.
Here is filter shown above mounted on my tractor (with the original filter sitting next to it just for comparison).
Hello Jim.ME
Thanks for the reply
I?m looking for the same primary fuel filter that?s shown at the
very top.
It looks strangely brand new with the correct spacing between
the mounting holes.
Iv been looking everywhere online with no luck.
Starting to think I might have to try an alternative approach.
(quoted from post at 01:54:49 04/24/20) Hello Jim.ME
very top.
the mounting holes.
You are looking for this assembly?
If I am reading right in the parts book that is MF part number 890971M91 (Perkins part number 2656754) and was used on tractors prior to s/n 240398. Maybe someone here will answer that they have a one, I expect it will be used if they do. You can search on line with the part numbers and check with MF, CAT, and Perkins dealers.
I read the post Cormiers Cove made as he was looking for a spin on to replace a filter Like that. I really doubt that was a picture of his filter as he said his was rusted through and had a pin hole. My guess is that one is obsolete and you will need to find something else for a filter.
(quoted from post at 03:45:24 04/24/20)
Here in the States you are only going to find that filter housing like Cormiers Cove posted used (it uses a cartridge type filter element). Apparently it looks like that filter housing can be found new in the UK.
(quoted from post at 07:45:53 04/24/20) Thanks guys, appreciate the help
Tomtom1988,
I see you on other forums, jumping into posts on other subjects (called Hi-jacking) looking for this filter and asking about a diverter valve. That is kind of rude, it won't gain you a lot in the end. Please start new posts for your needs. Off subject things in an unrelated post maybe overlooked by someone with your answer, because they didn't read a post they were not interested in.
As for this filter you asked about here and in the post asking about goldsburg. Are you doing an exact restoration and need this exact filter or do you want a filter to replace it so you can run your tractor? As posted here earlier finding that exact filter is a long shot. A proper replacement, like a newer spin-on, will run your tractor just fine and may give better service life. You might have to fabricate the mounting and rework the fuel lines a bit. What is your end goal in this matter?
(From your question in the post about concrete mixes) A diverter valve is used to swap a hydraulic source between to different end attachments, it is not intended to be a control valve to operate a function. They are commonly used for such as separating 3 point hitch arms and a remote cylinder on tractors where they worked at the same time when the control lever was moved. Some loader backhoes used a diverter valve to switch the hydraulic supply between the loader control valve and the backhoe control valve. You can use a diverter valve to separate the functions and still control each with the one valve. Make a new post, on an appropriate forum, and describe what you want to do, what you are using for a source, what the end use attachment is, and what if anything you have for parts you would like to use. People will be able to better help you, without it getting mixed up in something unrelated, if you do this. I'm not trying to offend you, just trying to help you out in getting answers you can use.
