FUEL FILTER REPLACEMENT
If you're referring to a 3 cyl 2040 push on extended tab on filter clamp to unlatch clamp,remove clamp & filter,install new filter & clamp,open bleed screw(parts key 7) on filter housing,pump lever on lift pump until air free fuel squirts out,close bleed screw & crank engine. Filter from JD dealer is AR50041 Fuel Filter - ELEMENT ,FUEL FILTER ADD 12.71 USD
Yesterdays Tractors parts dept. also sell this filter.
