Fuel Gauge not Working
Airborne
The fuel gauge on my 2018 Massey Ferguson 1705 has stopped working. All other dash gauges and lights work. All known fuses have been checked. Suggestions anyone.
The tractor is still under warranty so I haven't dug around to much on the dash. The tank ground is most likely the problem. I never considered it before. I did a lot of bush hogging this summer and much debris accumulated under the seat and surrounding area. The ground will be the first place I'll check today.
Thanks for the tip. Will update as necessary.
Fellows I want to offer my sincerest apologies, I made and errant post. I meant to post about my engine temp gauge. The only excuse I have is "growing old ain't for sissy's" and lack of morning "caffeine" intake. Your responses are very valid and will be seriously considered should a fuel gauge become an issue.
So my issue the Temp Gauge only
(quoted from post at 08:35:12 10/27/19) Fellows I want to offer my sincerest apologies, I made and errant post. I meant to post about my engine temp gauge. The only excuse I have is "growing old ain't for sissy's" and lack of morning "caffeine" intake. Your responses are very valid and will be seriously considered should a fuel gauge become an issue.
Find temp sender and jumper terminal to ground.
Gauge should rise to "HOT". If it now does, sender is bad.
If no gauge movement, there's a a gauge or wiring issue.
I'm a Vietnam Infantry Paratrooper Veteran. 173rd Airborne Brigade. The early Years. CIB and Bronze Star with V Device.
Thank You for asking.
(quoted from post at 13:13:27 10/27/19)
My cousin Sonny was with the 173rd for the fighting around DakTo
I performed ground check as suggested but no movement on gauge needle. Thanks for the suggestion. I will drop tractor at dealer this week for evaluation and fix. Will update when I have more info.
There are a few of us crazy guys around. Personally I tried sinking a perfectly good ship (submarine) instead of jumping out of a perfectly good airplane!
Another factor was that there are more airplanes in the bottom of the ocean that submarines in the sky, thus my choice of service!
