Mack69
I just got a new aftermarket fuel gauge for my John deere 1020 tractor. After I installed it and got it wired up the gauge shows full when the tank is only half full. Any idea what might be wrong
(quoted from post at 17:39:22 07/12/21) I just got a new aftermarket fuel gauge for my John deere 1020 tractor. After I installed it and got it wired up the gauge shows full when the tank is only half full. Any idea what might be wrong
Electric gauges will not read properly if the gauge ohm range doesn't match the ohm range of the sender. My guess is you have the wrong gauge to match your sender. There were different 1020s and they had different parts books and not all parts were interchangeable, fuel gauges being one. Is your 1020 a Dubuque built one or a Mannheim built one? Did you use the correct part number when to find the gauge you got or did you go by the ad saying it was for a 1020. The gauges are different on them, and there seem to be more aftermarket gauges that fit the Mannheim tractors than the Dubuque ones, from what I found when looking into a fuel gauge for a Dubuque 2030.
