DRD in Pa
I have an 801 series tractor that the fuel gauge flips back and forth from empty to full, sometimes it will read the fuel level correctly ,is it possible to repair the sender unit, or does it have to be replaced?
Congratulations on having a fuel gauge that even moves at all! I don"t think I"ve ever seen a X01 tractor with a working gauge. The sending unit is pretty well sealed up and you will most likely need to buy a new one.
Could in fact be a bad sending unit or it could be as simple as a poor tank ground and or a bad wire from the tank sending unit to the gauge. I would check the wiring and make sure it is good and that the tank has a good ground
