jerseysierra
What is the normal pressure for this gauge? Reading 2 PSI at idle, engine is 310TD. I just changed the fuel filter next to it and I also cleaned the screen in the sediment bowl which was covered in goo (algae?)
Now that screen is clean seems to run much better. The sediment bowl screen is a super fine mesh. Wondering if that is causing a restriction? ie. would it be better to remove the screen and rely on the primary filter? OR switch to a coarser screen?
