Fuel Pump Fittings
I purchased a Ford DEXTA 957E-7005 and the fuel pump was bad, purchased a new one. I need the two (2) fuel line compression fittings-in and out- for the new fuel pump. I have made a wide search and have not located any. I have one (1) fitting that will fit but it bottoms out of threds and will not get tight. Is there a source that I can purchase these fittings?
NOT exactly sure what a "DEXTA 957E-7005" is, but if it is simply a normal DEXTA, low pressure fuel line nuts and ferrules are still available from the FIAT dba CNH dealer.
Nut: #117757S36(replaces 81819627).
Ferrule: #81762064, (replaces 119987ES).
NOT sure what (if anything) is different from an "off the shelf" 1/4" ferrule from a auto parts, or home improvement store, but the (threaded on the outside) nut might be a bit tough to find outside of from CNH.
