Fuel Pump Seal Kit
oldnellie
The fuel stop level shaft is leaking fuel. I suspect the "O" rings need to be replaced. The egg shape label plate is on the fuel pump but I am unable to read any information on it. All I can see is a few scratches where the previous owner scraped the paint off. What information will I need in order to order the correct seal kit. It is a 1958 Massey Ferguson 135 with a 4 cyl. Perkins engine.
Are you sure you don't have the Standard Motors 23C four cylinder diesel in a model 35? Never was a 1958 135 four cylinder diesel, 135 and late 35 used Perkins three cylinder diesels after MF bought Perkins in 1959. My 1958 TO-35 has the 23C in it.
Dieseltech, you are right on with your information. I ran the prefixes to the serial number and I do have a 23C four cylinder engine and it is not a MF135 but a FE35. The only thing I got right is the year, 1958. Now that we know that it is a 23C engine, will the same pump seal kit fit all 23C's? Upon closer inspection, I am able to determine what looks like a serial number on the fuel pump but will need better lighting to hopefully recover this number and/or model no. I have owned this tractor for over 25 years always believing that it was a MF135 with a Perkins engine.
