Geoff NY
I have a ford 515 (same as a 4600) that starts really hard. A frind has ford and suggested that the fuel injector pump could be the culprit. How tough is it to rebuild? It has a leak around one of the caps on the plungers, does anyone get them rebuilt or do you do the rebuild?
Geoff
A little more information might help. Engine hours? A brief history of the tractor?
A diesel shop can repair your pump for you, but you should check a few things first. Change fuel filter(s) Clean wet filter, or replace paper air filter(s).
Last, remove the fuel injectors, do a compression test and have the injectors cleaned and re-set.
Then if everything else is OK, it would be time to rebuild the injection pump.
Brian
starts hard?
starter labors?
spins slow?
spins over and no pop off?
any smoke when cranking?
what color?
start easier hot?
