fuel tank bracket fabrication
OldTrucker
Has anyone removed the fuel tank from a 9n Ford hood and fabricated brackets to mount it from the engine or frame? I am an older person and if i can do this it will make the hood lighter for removal. Any help or suggestions will be appreciated.
I don t want to come across as an a-- but you only need to remove
it for an overhaul. I took two off,one beacuse I didn't know
better, and one to pull the head.
(quoted from post at 19:14:31 04/01/22) Has anyone removed the fuel tank from a 9n Ford hood and fabricated brackets to mount it from the engine or frame? I am an older person and if i can do this it will make the hood lighter for removal. Any help or suggestions will be appreciated.
It would be MUCH simpler to rig up a hoist to an overhead beam or use a "cherry picker"/engine hoist to lift the hood and tank as a unit.
Or, with the tank empty, line up a helper for a minute or two and lift it off.
