Lake County Tractor
What is the best way to clean and test a fuel tank. I have a 52 8N I'm working on and want to make sure the fuel tank is safe and clean but not sure where to start. Looking for suggestions.
ast week I used bungie cords to strap my welder tank to the wheel of my tractor. Put a quart of acetone and about 2 cups of bolts, nuts, screws in it & mowed for 2 hours. Washed with water, blow dried with air, filled it with diesel to void all aor pockets. Will dump that into a clean white bucket & examine. If nice, will rinse with non-ethanol gasoline (not the e- crap that caused the problem) & fill & see if I can keep it full from now on.(quoted from post at 22:19:25 08/10/17) Thank you for the valuable info I'll get working on that. I might look into this redkote product if the tank looks to bad maybe I'll consider a new one.
don't mind the 'slam', I can take it, but you need to come over an "siphon" the stuff out of this tank. The best vacuum in the world would not clean up this tank. It needed a major beating!(quoted from post at 21:12:28 08/12/17)
Most people prefer to put a lot more work into it than this, but I bought a diesel tractor some fifteen years ago that gave me problems due to all the crud sloshing around in the tank. I siphoned the stuff out, no more problems. Too easy I guess.
(quoted from post at 19:43:37 08/12/17)don't mind the 'slam', I can take it, but you need to come over an "siphon" the stuff out of this tank. The best vacuum in the world would not clean up this tank. It needed a major beating!(quoted from post at 21:12:28 08/12/17)
(quoted from post at 08:25:19 08/13/17)(quoted from post at 19:43:37 08/12/17)don't mind the 'slam', I can take it, but you need to come over an "siphon" the stuff out of this tank. The best vacuum in the world would not clean up this tank. It needed a major beating!(quoted from post at 21:12:28 08/12/17)
JMOR, honestly not meant as a slam. Just stop and think for a moment about how frequently this topic comes up, and I have posted about what worked very well for me at least 25 times but never any interest. Some tanks come off fairly easily but the tanks of the Fords like I have are a major project. Yes there are different degrees.
OK. This was a lot worse than just slime....it was accompanied with dried/hardened slime & rust. Abrasion was about the only way I see to clean that up.
Reminds me of the 'sticky bomb' that Tom Hanks used in Saving Private Ryan. lol(quoted from post at 13:04:47 08/11/17) My![]()
