fuel tank cleaning
To help the process, drop a 1/4 or 5/16" small chain in the tank and use it to scrub the bottom. Rock the tank over a saw horse every so often and eventually you can hear when the chain is rubbing metal to metal. You may have to drain and renew the gas a few times.
I used Sodium Hydroxide to clean out a nasty gas tank once. I liked the guy who strapped his gas tank to a rear tractor wheel and drove it
around. Lye, if left in the tank too long, will eat right through it.
E85 works wonders. Cleaned my Case 930 48 gal tank. Filled 3 times just to make sure last draining was clean. Let each fill soak a couple days. 1st drain was deep black/brown. Last one was clear.
E85 does work good but can be harder to find than ethanol free gas depending on your location.
Not to many stations sell it here.
If you can pull the tank you only need enough to have a few inches in the bottom. Then rotate the tank to another side etc. etc.
