Fuel tank liner
Well don't know if it is the latest and greatest but when I had a leak, not from rust, on the tank of my BN this is what I used:
https://caswellplating.com/caswell-epoxy-gas-tank-sealer-car-tanks-up-to-20-gal-1-quart.html
Did not hurt either that they are about 45 minute ride from my house and a got a little bit of a discount for paying cash and picking up in person!
Of course I had to get the Dragon's Blood (Red) version so my tank is color matched inside and out!
*** Just noticed this note on the Caswell Site for the sealer***
Availability:Available Approx Oct 15
This post was edited by kshansen on 09/09/2023 at 04:51 pm.
Do Not use Kreme It will beak down and make a mess
I have used Red Kote with success on relatively clean tanks It claims to seal rust but I
don't know how bad your tank is
Good luck
Go to oreilys and have them order you a quart of redkote. Its from damon industries I think. I have done lots and lots of cars/tractor and small engines. I have never ever had a failure. Follow the directions and you will be good
This subject seems to pop up pretty frequently on here. There are lots of thoughts/opinions. The general consensus usually seems to be if you're tank's leaking, RedKote or the POR-15 liners are best. If it's not leaking, but just rusty, you're better off to clean/strip and give it a few rinses in WD40 to coat the bare surfaces. Nothing wrong with a liner if the prep work's one right and the tank is properly stripped/cleaned before applying it, but there are a lot of horror stories of liners not put in properly that start to disintegrate and plug up the fuel system. Prep work is key, regardless of brand.
I have an old Fiat convertible I'm running off a boat tank in the back seat, because the PO did a lousy job prepping for the liner. It started to dissolve, and once they start to dissolve it's a huge pain to try and get it all stripped out.
