Fuel tank on 2n
I'm trying to drain my fuel tank ,I removed fuel line from carburetor out of sediment bowl and opened the valve. No gas coming out . Is there a trick?
(quoted from post at 18:45:53 07/18/16) I'm trying to drain my fuel tank ,I removed fuel line from carburetor out of sediment bowl and opened the valve. No gas coming out . Is there a trick?
ounds like strainer on top of valve clogger & the small passages in valve as well. Remove it from tank & it will drain. Then disassemble valve and clean it & all passages. I have found parts of vegetation, seeds, and insect parts in them.
brandon, i'm guessing you've gt about an inch of gas in the tank.
those sediment bowls come mislabeled. the knob refers to main and reserve - it should say main and...
