Fuel Tank Repair
Moonlite37
My Kiota tractor has a leak in the fuel tank. I was wondering if anyone had any experience repairing a plastic diesel tank.
Depends on why it's leaking.
If stress cracked, punctured, rubbed through, and the cause can be prevented from happening again, then yes it can most likely be welded.
You can buy the welding kit at Harbor Freight. Works like a soldering iron with plastic.
But if it's sun baked, major damaged then no, best replace it.
Seal -All should work, it comes in a Bright yellow and Red tube,farm supply and automotive stores have it, But it got to sit 24 hours,
