Fuel tap Seal
Tentman
Hello Guys
Is there any secret goop or method for sealing taps into fuel tanks ??
My MF 165 tap leaks, and I have a new one to hand. However it needs to "register" or tighten in the right spot so the fuel line will connect.
Cheers - Foster
"Gasoila" is one such product.
The "hard set" version works GREAT when the parts have to be "registered", as you say.
<img src = "http://www.gasoila.com/images/prodpics/xl/Hard-SetSealant.jpg">
Thanks Bob - I knew there'd be just the right stuff but unless you know the right "words" (i.e. "hard set" in this case) you're just as likely to get a blank look from the store clerk that sorta makes you think you're questioning his parentage !!
