FUEL TRANSFER PUMP
WNYBill
Anybody got one of these TeraPump A-TREP03-001 TREP03 Multi-Purpose Powered Liquid Transfer Pump - 110V AC
/ 12VDC, 4 GPM
Battery or plug in, 8 foot hose, 4 GPM amd a valve. About $50.00, looks like it is not a toy and might just
work. Doesn't say "Diesel Only", so I presume it can safely pump gasoline.
Bill
I think most of the "bad" reviews were for the units that use 4 AA or 2 D batteries. The one I am talking about uses a 12 volt vehicle battery or plugs into 110. Looks like the pump is in the fuel pick-up so it pushes rather than sucks.
Bill
I've read a lot of good reviews on the TeraPump units. Believe it or not I have one of the "stick" style that take two D batteries (shown below). I got it from Amazon for around $19. It works perfectly. I've had it for (wait for it) SEVEN YEARS and it still has the original batteries. I use it each fall to pump the gasoline out of the tanks on my various small engines. I originally thought it would probably only last a few years especially using it with gasoline. I even used it once to pump 5 gallons of diesel fuel out of my tractor. It took a while but I just hit the power button and let it run while I did other things.
