(quoted from post at 22:59:48 06/01/12) Is it best to use hi test gasoline? And how about lead additives? 1939 9n.
hink about it.........did that kind of stuff exist in 1939????? :cry:
talohio........would it surprize you to learn that the low compression (6:1) 1939 N-engine was designed to run on 70-octain unleaded gasoline??? The issue with modern gasoline is the ethanol additive is unfriendly to carburetor float valve and causes it to "stick". Hi-test gas usually does NOT have ethanol (alcohol) added to it. The ONLY alcohol I want is in my Bourbon and Branch ........the smooth sippin' Dell
yes i am suprised i have been using med to high octane for the last 5years and a some lead additive. Have never been able to get a good answer on the subject.AS i wasent around in 1939 i couldent say what was avaliable then.
Tal, a few points to consider:
There is no such thing as lead additive - It's illegal.
Originally the lead was added as a valve seat lubricant which is not required for the N's as they have hardened valve seats.
I normally use high test not for the higher octane rating but it supposedly has less alcohol in it but I've never been able to confirm this.
The only additive I use is 8ozs of ATF in every 5 gallon can - This seems to reduce water condensing while stored and also acts as a top cylinder lubricant.
(quoted from post at 04:50:48 06/02/12) Tal, a few points to consider:
Valve seat lubricant = another myth. A little history on the introduction of tetraethyl lead (TEL) as a gasoline additive. If you don't believe Wiki just research Thomas Midgely.
[i:539d2d3a47][Thomas] Midgley began working at General Motors in 1916. In December 1921, while working under the direction of Kettering at Dayton Research Laboratories, a subsidiary of General Motors, Midgley discovered that the addition of TEL to gasoline prevented "knocking" in internal combustion engines. The company named the substance "Ethyl", avoiding all mention of lead in reports and advertising. Oil companies and automobile manufacturers, especially General Motors which owned the patent jointly filed by Kettering and Midgley, promoted the TEL additive as a superior [u:539d2d3a47][b:539d2d3a47]alternative to ethanol or ethanol-blended fuels[/b:539d2d3a47][/u:539d2d3a47], on which they could make very little profit.[4] In December 1922, the American Chemical Society awarded Midgley the 1923 Nichols Medal for the "Use of Anti-Knock Compounds in Motor Fuels".[5] This was the first of several major awards he earned during his career.[3]
In April 1923, General Motors created the General Motors Chemical Company (GMCC) to supervise the production of TEL by the DuPont company. Kettering was elected as president, and Midgley was vice president. However, after two deaths and several cases of lead poisoning at the TEL prototype plant in Dayton, Ohio, the staff at Dayton was said in 1924 to be "depressed to the point of considering giving up the whole tetraethyl lead program."[6] Over the course of the next year, eight more people would die at DuPont's Deepwater, New Jersey plant.[6]
In 1924, dissatisfied with the speed of DuPont's TEL production using their "bromide process", General Motors and Standard Oil Company of New Jersey (now known as ExxonMobil) created the Ethyl Gasoline Corporation to produce and market TEL. Ethyl Corporation built a new chemical plant using a high-temperature ethyl chloride process at the Bayway Refinery in New Jersey.[6] Within the first two months of its operation however, the new plant was plagued by more cases of lead poisoning, hallucinations, insanity, and then five deaths in quick succession.
On October 30, 1924, Midgley participated in a press conference to demonstrate the apparent safety of TEL. In this demonstration, he poured TEL over his hands, then placed a bottle of the chemical under his nose and inhaled its vapor for sixty seconds, declaring that he could do this every day without succumbing to any problems whatsoever.[4][7] However, the State of New Jersey ordered the Bayway plant to be closed a few days later, and Jersey Standard was forbidden to manufacture TEL there again without state permission. Midgley himself was careful to avoid mentioning to the press that he required nearly a year to recover from the lead poisoning brought on by his demonstration at the press conference.[citation needed] According to Deborah Blum in The Poisoner's Handbook (p. 123), Midgley sought treatment for lead poisoning in Europe a few months after his demonstration at the press conference. Midgley was relieved of his position as vice president of GMCC in April 1925, reportedly due to his inexperience inorganizational matters, but he remained an employee of General Motors
[/i:539d2d3a47]
Any anti-wear properties of TEL were incidental at best - it was developed and marketed as an anti-knock additive (e.g octane booster). Also worth noting that as far back as 1920 ethanol was an alternative octane booster....
TOH
Thanks more good info and great picture.And your right about the additive it is a LEAD REPLACEMENT ADDITIVE and as most additive not needed.
Back when that tractor was made was also the war years and gas was not very good and low octane etc and that tractor ran fine on that stuff so now today you can still run it on the cheapest gas you can find and no need for any additives. Ya if you want to clean it out and lube it some put a qt. of ATF into 5 gal. of gas and run that and it will help clean out carbon and also lube the valves etc
If it didn't provide any lubricating value, why was there a problem with engines that did not have hardened valve seats prone to seat wear?
The following quoted from Wiki:
[i:92a2cf5399][b:92a2cf5399]"Tetraethyl lead was extensively used as an additive to gasoline, wherein it served as an effective antiknock agent and prevented exhaust valve and seat wear."[/b:92a2cf5399][/i:92a2cf5399]
http://en.wikipedia.org/wiki/Tetraethyllead[/url]
(quoted from post at 17:06:03 06/02/12)
[i:d220e6f1cd][b:d220e6f1cd]"Tetraethyl lead was extensively used as an additive to gasoline, wherein it served as an effective antiknock agent and prevented exhaust valve and seat wear."[/b:d220e6f1cd][/i:d220e6f1cd]
Quoted from me:
[u:d220e6f1cd][i:d220e6f1cd]Any anti-wear properties of TEL were [b:d220e6f1cd]incidental[/b:d220e6f1cd] at best - it was developed and marketed as an anti-knock additive (e.g octane booster).[/i:d220e6f1cd][/u:d220e6f1cd]
My point is that it was not developed as a wear additive and when removed from gasoline the wear issue was easily addressed with the use of hardened valve seats and replacement additives. In any event at 23HP and 2000 RPM the flathead Ford (and many other older engines) had no issues with valve seat recission - with or without TEL or hardened valve seats. Valve seat recission became an issue with the introduction of higher compression and more powerful engines where increased contact welding created abrasive seat conditions that accelerated erosion. AMOCO Premium "white gas" (lead free) was marketed for almost 50 years prior to the banning of TEL in the 70's. It was widely acclaimed as a superior motor fuel with a higher octane as well as cleaner burning with none of the valve and spark plug deposits you got with TEL. You paid a premium for it at the pump and it was a favorite of the muscle car crowd.
TOH
besides what has been said. the higher the octane of the fuel.. the HARDER it is to ignite.
you want LOW octane fuel in an N.. make it fire easier.
our LOW octane fuel is plenty knock proof for that low rpm/compression N
