Some of my issues may have been answered in the response to Tom888fish by Bruce, but I might have two questions left:
1. IF I replace the distributor (1949 8N front mount, 12V conversion that has been running), should I go with rebuilt, new, John Smith, .. . ? Looks like $160 at shops like nnalert, $120-130 on eBay or Amazon, "pending" (for 6V, not 12V) at John Smith.
2. Should I try something else before getting the distributor:
My mistake, left the key on and the battery ran down to stone dead. Tried to recharge, but neither of my rechargers wanted to indicate it had reached full charge. Battery check at Advance Auto said amps was good, voltage a little low at 12.39V. Cranked fine but would not start.
Figured I might have burned the points with the key left on -- seems like I saw that somewhere -- so I got new tune-up kit at TSC (#1238070). New points would not open no matter how I positioned the adjustment screw -- just rotates 360 degrees, right? Got mad and went to NAPA for another set of points (Echline CS35). They open only about 6-8 thou no matter how I positioned the adjustment screw. Haven't even gotten to putting in the new plugs after I gapped them.
Since I broke the "cannot replace distributor out of sync with camshaft tab" on the old distributor shaft, I replaced the distributor shaft with a new one. Tractor has run several months just fine since then (so I'm guessing the distributor cam is not worn out already).
OK, broken tab, left key on, dead battery. . . maybe I should try another hobby, but the gravel drive needs scraping and I enjoy running the ole 8N. AND, I've learned to remove the front mount distributor without much problem!
