Funk conversion water pump
Auto Zone lists four water pumps w/pics . Most likely the pick up style was used .
1 - 1950 F1 w/3.7L
m58-469
2,3,4 - 1950 Ford Custom w/3.7L
m58-465
m68-435
m68-410
I don't think it matters which motor you have since all three types were used in the aftermarket conversions , some even had the overhead valve 6's
The intake/exhaust manifolds and water pumps vary .
Does your Funk have the cast iron oil pan or the early c channel rails ?
All of the tune up parts & gaskets along with most of the rebuild parts are still available at most auto part stores .
Off the top of my head I cannot remember the differences. But, Ford did put the Industrial engine in a cab-over-engine delivery truck. As best I can remember you can tell by the intake and exhaust manifold, but I have forgotten exactly how. I know mine matched pics I saw once of the Industrial engine but did not match with the car engine. I don't know about the so-called truck engine.
My engine number is 1HA6015A indicating a 1951 H-Series engine with 226 CID. Located on left side of engine block down at the bottom just above the oil pan. The distributer is located on the left side and center of the block.
