• Thread starter Thread starter wi
  • Start date Start date
wi
Gotta start with the saying above our computer desk"Success is NOT to be measured by how much material wealth is posessed.but whether you are able to CREATE AT WILL what you NEED" well I"m going to put a fuse block in our 706 I.H.
Most tractor fires seem to be started with the electrical circuits. No in line protection,old wire thats brittle & chaffed. I ordered a fuse block and notice there isn"t a buss bar in between the circuit fuse holders. The fuse block came completely void of instructions on how to power up the block. We (my son & I) are going to install a Cab with interior lights, lights atop the cab. rear lights and the original front cowling (weak Lights)that glow yellow. Must be original set up from the factory. Putting a 72 amp alternator on the 706 as the generator is shot. We purchased the tractor(our 1st one ever)
and all the light wires was cut. The guy that owned it must have had no power to any thing but battery power to the distributor. Now you can well imagine that any information on how to power up the fuse block would in deed be welcomed. From reading the posts, there is a lot of knowledge to be shared. In my mind there MUST be Buss bars inside the fuse block so as to avoid a whole gob of wire wrapped together to gain individual circuits. I"m willing to bet that one of you fellows did what I am trying to do.Why there was never a fuse block installed at the factory is beyond my imagination. I can state that neither one of us is farmers but have need for a reliable tractor. We are installing a schwartz loader that didn"t come off a 706(as we were told) but some other year I.H. Now thats a chore. New tangs, new cylinders etc,I must explain that we are superb welders and metal workers. Not much we cant accomplish with a great deal of thought, and one heck of a lot of PAYING ATTENTION TO DETAIL. So as not to sound as we know it all and as you can see by this post WE DON"T.
So now it"s your turn to teach an OLD(73year old)dog new tricks .Will be lookin forward to your suggestions and comments. THANKS
I am also 73 going onto 90 some days and sorry I can't help you but to give you a caveat: do not bolt stuff to a plastic board or block without sizeable metal washers on both sides. I know I know a chance for shorts if posts are too close. What happens to plasic is cold flow under pressure, allowing the torque you put on the bolted electrical connectors to get loose. Loose connections equal higher resistance equals heat which softens the plastic even more.... I won't tell you what tractor company I worked for where I learned that.
Thanks Leo!!! what you state is good information. I will take your advice. The fuse block I ordered is an exact copy of Chev/G.M.It came with the brass push in tabs for the fuses, However there is several channels through out the bottom. I figured that is where the bus bars are to be located. I guess I'll have to visit a salvage yard to see how the fuses blocks are factory fited with bus bars. My son works for a farmer and he drives a stieger (2006) so he knows that all their equiptment being new has fuses in a factory fuse holder. Sure wish i could afford something like that. then there would be no necessity to install amything ,at least for a while. Restoring any motorized equiptment takes time and knowledge and some hard cold cash that these days doesn't come easily . In case you need to see what type of fuse block I got the name of the Co. is KEEFE PERFORMANCE, and the fuse block is the delphi fuse block with high pedalstal legs in opposed direction. Again Leo, thanks
LOU.
I would recommend a fuse block with a solid base/back because corrosion will develop over time if mounted on the metal panel or frame of your tractor. #2 it should have a weatherproof cover on it also .You are absolutely correct that the individual circuits should EACH be individually Protected. On my three old Ford tractors I have installed the "Older glass tube 1 1/4" by 1 1/4" style fuses because of cost and easy to see their condition. Having worked for BUSS FUSES for 24 yrs makes me a real believer in their use.If you have or need more info contact me
